Error in meshing
Hello While meshing following error comes. Initilization failed to mesh nodes. ERROR:TG_mehs_Domain failed with error code 1 ERROR:Tetrahedral meshing has failed for volume 35 This is usually caused by problem in the face mesh.Check the slewnesses of your face mesh and make sure the face mesh sizes are not too large in areas of small gaps. Please give the solution to remove the above error. Thanking you Mannsonu
Re: Error in meshing
check ur edge mesh setting and then do face mesh and check if any large gaps r there or not.
Thanks, In my problem there is a container of 1800*3700*2400mm and in that there is sheet of 0.672mm thicknes and 770 mm width and 1300 height. i first subtracted the sheet from container. and then meshing then above meshing problem given
From MannsSonu |
since ur sheet is very thin(compared to other dimensions), give a proper interval size to ur sheet thikness and proceed, else use size function,
