calculation of pressure difference wrong?
Old   January 5, 2006, 10:06
Default calculation of pressure difference wrong?
Ralf Schmidt
I'm optimizing an apparatus in terms of maximum flow homogeneity. For this case, I use different shapes of the redirection area (varying flap geometry, deflector radii,..) from the air-intake to the region, where the velocity of the flow should be as homogeneous as possible.
So far, I figured out a set of optimal parameters. The next question is to minimize the pressure drop along the apparatus. THE SIMULATION IN Fluent SHOWS, THAT THE SET OF OPTIMAL FLOW HOMOGENEITY PARAMETERS RETURNS THE LOWEST PRESSURE DROP.
Isn't that contrariety? Many experts told me, that attaining flow homogeneity involves always having a high pressure drop.
So does Fluent give wrong pressure differences (using "Area-weighted-Average" static pressure - see discussion http://www.cfd-online.com/Forum/fluent.cgi?read=34573)
Or is it me, how is thinking wrong…
Any Idea???
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Pneumatic simulation - moving wall as a function of a pressure difference jbmackay OpenFOAM 0 September 22, 2010 15:51
difference between st. pressure and tot pressure jai CFX 7 December 12, 2008 03:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
