negative cell volume
hi
i am dealing with a vibrating membrane with the working fluid as air. I have a problem in dynamic meshing that says negative cell volume found.how to deal with the problem what are the probable reasons for that. Can anybody suggest something in this regard thank you in anticipation ALFIN |
Re: negative cell volume
HELLO,TEH NEGATIVE CELL REMOVED BY REDUCING INTERVAL COUNT/SIZE MANOJKUMAR
You also suggested to use the smooth volume mesh function to reduce inveted elements(negative volume).Smooth the volume meshed many times until the negative volume reduce completely.
