Home > Forums > FLUENT
the periodic time for unsteady cases
Old   January 9, 2006, 03:34
Default the periodic time for unsteady cases
frank
Hi, can anyone give me some information about the periodic time for the unsteady cases--outflow around bluff bodies? How to calculate?
Thanks a lot
Old   January 16, 2006, 10:28
Default Re: the periodic time for unsteady cases
Jason
A first approximation would be to estimate the Strouhal Number (a cylinder is generally assumed to be around .2 depending on your Reynold's number). From there you can calculate the vortex shedding frequency and according to the Fluent manual, you're going to want about 20 iterations per shedding cycle. If you can't find the Strouhal number for your geometry, then try to find the Strouhal number for the closest shape and use a smaller time step than would be needed. For example, if you're geometry is somewhat cylindrical, then you can assume a St of .2... if that gives you a time step size of .02 seconds, then maybe you run with .01 seconds. If your model keeps converging within a few iterations, then you can up the time step. If the model doesn't converge within the 30 time steps, then you should try an even smaller time step. You want the model to converge between 10 and 30 iterations per time step. Really small time steps shouldn't be a surprise depending on your model.
Hope this helps, and good luck, Jason
Thread Tools
Trackbacks are On
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
