Fluid Vs. Wall Temperature
Old   January 13, 2006, 00:09
Default Fluid Vs. Wall Temperature
Jack Smith
Hi, I am modelling a fluid to solid heat transfer problem. The fluid is at a very high temperature (2100 K), but when I get the solution the solid wall in which it comes in contact with shows a very small increase in temperature (initial 300 K, final ~350 K). Also the material of the solid is copper. Does anybody have an idea what values I should play with to get some reasonable temperatures (exp. anlaysis gives me a wall temp. of around 650 K) I am using a Spart-allmaras turbulent solver for this 3D problem.
Thanks.
Old   January 13, 2006, 09:50
Default Re: Fluid Vs. Wall Temperature
mat w
Try different viscous models - im using k-e-RNG for some heat sink analyses. It works OK but I'm not going up to the temperatures you are.
I also had to go for the enhanced wall treatment which meant adjusting my grid to get the correct y+ value.
Also, just a thought but is your fluid density correct at that temp?
Sorry, I can't offer more help, but I got past the problem I faced with alot of trial and error and even more patience, good luck
Old   January 14, 2006, 14:03
Jack Smith
Thanks, I am also playing around with all the vicous models. Till now the spart allmaras has given me the best convergence and results. also my fluid is ideal gas, so fluent takes care of all the density matters. Also could you tell me, how much of a rise in temperature are you getting and what y+ values are you trying for?
Old   January 15, 2006, 10:07
mat w
I'm only dealing with the heat sinks you might find in your computer, so only a 40degC temp rise. The y+ values i go for on the enhanced wall treatments are around 1 - easier said than done if you have a large 3D model.
Another problem I've come across are extremely high heat transfer coefficients at the joints between the pin and pin endwall (in the region of a few thousand W/m^2.K). These seem to arise when the cells in the boundary layers of these surfaces have high skew. So another tip I'd suggest is make sure the boundary layer grid has a low equi angle skew as possible.
Good luck with it!
Old   January 19, 2006, 00:08
Prabakaran M K
Dear jack smith,
The problem lies in the near wall treatment. U should provide more layers near the wall to capture the boundary layer and give the correct values at the solid interface.
SA model is only for the beginners. it will give you approx. results compared to RNG k-e. So better try with RNG k-e and more refined mesh near the solid-fluid interface.
mail ur email id.
all the best.
MKP
Old   January 25, 2006, 11:42
Thomas
What kind of bc have u applied to the waal? a convective bc? what do u mean by initial temperature? are u studying an unsteady case? If u expect so different temperatures between the flow and the wall u should get more attention in the radiative model that u're using than in the turbulent model. What kind of model are u using and why?
thomas
Error message: Insufficient Catalogue Size Paresh Jain CFX 32 February 3, 2021 03:37
How to adjust wall temperature nutow FLUENT 0 September 4, 2011 05:37
sharp temperature decrease near the wall dace CFX 0 January 28, 2009 08:23
How to input the wall temperature b.c.? Jimmy Siemens 9 March 14, 2008 09:31
wall temperature setting nianqi CFX 0 October 16, 2006 06:53
