Do virtual and real lines cause different results?
Old   January 12, 2006, 02:11
Default Do virtual and real lines cause different results?
Pathway
If we model a virtual line (virtual surface) in Gambit, the result will same as the real line (real surface) in Fluent? Thanks!
Old   January 14, 2006, 12:58
Default Re: Do virtual and real lines cause different resu
Freeman
Yes, indeed. Virtual geometry is only a tool used in Gambit to help user making complex geometries and, for example, to be able to have geometry "in the background"; I mean, if you merge 2 edges into one virtual edge, the original 2 edges will be send to the background. You don't see it, but if you delete that merged edge, you will see the original 2 edges again: they will come to the foreground again.
Hope this has been clear enough. Good luck!
Old   January 15, 2006, 08:28
Ahmed
Freeman Thank you very much for this short and concise explanation I have always avoided the use of the so called virtual geometry because I never understood why it was there Why not write an article about that point on the WIKI
[GAMBIT] Difference between real & virtual line, face, & volume?? teguhtf ANSYS Meshing & Geometry 2 October 5, 2009 07:47
virtual or real flow volume for wind tunnel? qm FLUENT 1 January 9, 2009 15:26
GAMBIT - VIrtual edges and Real face Bridou FLUENT 1 July 22, 2007 12:57
Convert Real edges to Virtual in Gambit Freeman FLUENT 6 October 24, 2005 15:14
Virtual entities to real entities Lam FLUENT 2 August 22, 2003 06:17
