January 17, 2006, 13:21 |
k-e model
Hallo Fluent-users,
the residuals for the k and e fluctuate quite a bit during the iterations. Does anybody know what are the common causes (grid size too big or relaxation factor wrongly set??) and how to reduce the fluctuations to get convergence? Thanks a lot in advance! |
January 17, 2006, 15:01 |
Re: k-e model
Are you doing a steady simulation? In that case please try unsteady simulation at first. And then steady simulation can be started.
If you have the same problem, remesh your domain. Use denser grids for high gradient areas. Try this with using the same number of meshes you use now. |
Display Modes | |
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 05:41 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 04:20 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 26, 2009 00:27 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 07:19 |
Grid resolution for full-scale and down scaled model | gravis | Main CFD Forum | 0 | October 2, 2009 11:27 |
