grid check in FLUENT
Old   January 19, 2006, 20:21
Default grid check in FLUENT
wan aizon
I had a problem in grid check.When I check the grid, the result was like this,
WARNING!grid check failed
I didn't know why.Please anybody help me
Old   January 19, 2006, 21:41
Default Re: grid check in FLUENT
zxaar
do you have negative volumes in the mesh.
Old   January 20, 2006, 00:19
wan aizon
I comfirmed that there are no negative volume existed.
Old   January 20, 2006, 04:16
zxaar
humm, when you do the grid check, it writes lot of things before wwriting that the grid check failed. Did you see anything wrong in it. Left-right handedness issues etc. For us its difficult to say anything from just a grid check failed.
Old   January 20, 2006, 04:33
Mann Prasad
Hello, I am not sure but i think when u meshing in the Gambit then there is something error occur. chek every steps when u meshing the volume or face. There is message before mesh means it failed in intilization. Some time it failed in intilization but it show that mesh is complete. check first this then tell what happened. By Mann Prasad
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 03:33
HELP! grid check failed in parallel fluent restart FLUENT 0 March 5, 2011 09:55
Grid Check Fails in Parallel Processing Mode askance Main CFD Forum 0 October 20, 2010 10:11
Grid check fails after sliding mesh calculation Tito FLUENT 0 March 3, 2008 14:28
Grid for Fluent v.4 using Gambit? Ray Main CFD Forum 3 October 27, 1999 12:35
