Home > Forums > FLUENT
Shedding cycle time
Old   January 21, 2006, 07:06
Default Shedding cycle time
Giuseppe
Hello to all.
How can I read in Fluent, after my calculation, the shedding cycle time to calculate the Strouhal number?
Another question: Force coefficients use the reference area (in 3D?) to calculate itself; and in 2D which dimension uses? And how calculates Fluent the value of the area? In reference values panel Area is always equal to 1 m2.
Thanks a lot
Old   January 23, 2006, 00:23
Default Re: Shedding cycle time
Muhammad Shakaib
You can plot velocity vs time while calculations at some position in your domain.
Old   January 23, 2006, 12:23
Giuseppe
I didn't understand your answer, could you explain clearer?
Old   January 23, 2006, 23:55
Muhammad Shakaib
I expect that you are solving an unsteady problem. While solving you can place a monitoring point in the domain using solve-monitors-surface and then plot the velocity vs time step or flow time. Then you can see the time needed for one cycle using that plot. I hope this will help you.
Thanks
Thread Tools
Trackbacks are On
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 28 May 28, 2015 13:37
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 10:23
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 04:32
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 16:15
Physical Reason for stability of Implicit Schemes? radhakrishnan Main CFD Forum 25 December 7, 2000 16:25
