-   -   Creat or Import 2D airfoil profile. (http://www.cfd-online.com/Forums/fluent/39355-creat-import-2d-airfoil-profile.html)
Jackie January 23, 2006 04:06
Hi all
I'm attempting to simulate 2D flow around airfoil, but how can i make or import airfoil profile into Fluent. Could anybody suggest me pls.
Thank you in advance,
Jackie
philipov January 23, 2006 05:05
Re: Creat or Import 2D airfoil profile.
First you have to use Gambit to define domain and the airfoil. Then mesh it. If this is difficult, then use CAD product (AutoCAD) create profile, convert it into a region an export as a ACIS file. Import that file in Gambit and mesh it. That's it.
Jackie January 23, 2006 05:07
Thank you very much Phillipov.
Giuseppe January 23, 2006 06:49
To Philipov
How can I convert my dwg into a region and export as a Acis file? Thank you so much
philipov January 23, 2006 06:58
To Giuseppe: First of all you have to create closed line. Then Use command "region", mark the contour and it is OK. Go to File menu, Export.... Files of type - > I think second option is ACIS (*.sat) That's it!
Giuseppe January 23, 2006 07:48
To philipov.
OK philipov. Another question: when I import my file.sat in Gambit, how can I translate the design in a specific point? For example, if I have create a rectangle, how can I make to coincide a vertex of this with origin of axes (x,y)?
Thank you
philipov January 23, 2006 08:10
The imported object has one of the highest topology - face! Then use Face command button -> Muve/Copy Faces. Pick the face and enter the desired operation.
Giuseppe January 23, 2006 08:35
Philipov, excuse me still for the disturbance, but if I want to translate all the design and not only one face of it, how can I translate the origin of coordinates system in a specific point?
philipov January 23, 2006 08:53
No problem ..we are here to help eachother. If you want to translate all objects - select all and then apply translation. If you want more information - write to
philipov@data.bg
Giuseppe January 23, 2006 10:42
Philipov, how can I know in GAMBIT which are the coordinates of a vertex? thanks for your availability
philipov January 23, 2006 10:56
Give me an e-mail address to send you a picture from which you can see. 1.Go to VERTEX Command Button 2.Press the button that is on the second row, second button from right to left. Its name is "i". 3.Mark the vertex and press Apply
Giuseppe January 23, 2006 12:19
cardagiu@interfree.it
Thanks
Ahmed January 23, 2006 12:56
The easiest way is to download an already prepared mesh. Log on http://www.studentfluent.com/ then click on the mesh library. Enjoy the tutorials too.
a_run_91 May 10, 2013 17:39
Ansys fluent 13.0
Originally Posted by philipov
;128068
What if I am using ANSYS FLUENT and Solidworks? Saving as ACIS and importing to design modeler is not working..
Can any one throw some light on this ??:confused:
Far May 11, 2013 06:16
Are you pressing generate button? If still you have problem export in parasolid format.
