January 24, 2006, 02:05 |
A question about Fluid Mechanics and FLUENT
Dear users
In the Fluid Mechanics literature, for example written by Frank M. White in my case, we have a diagram of "flow losses in a gradual conical expansion region". It is the pressure loss curve for the flow in pipes situation. The pipe has a conical expansion and the loss K is clearly obtained from here. Now my problem is I can't verify any result of K although i have accomplished to do the analysis properly in Fluent. I have made many tries with several conical angles and several inlet velocity values. Just for an example i find K=0,09 although it is K=0,5-0,6 from the diagram in the textbooks. Do you have any experience on this or do you have any sugestions? I can send you my model. |
January 24, 2006, 02:58 |
Re: A question about Fluid Mechanics and FLUENT
I also have the same experience in the simulation of straight circular pipe. The result by K-e model is close to the that of Frank M. White But the The result by RSM model have a big difference though y+~1.
January 24, 2006, 03:07 |
I have used the k-e model. Do you think RSM improves the results? Big difference ı have though.
January 24, 2006, 04:50 |
No, I feel RSM model gives big difference between the simulation and empirical formula, k-e model gives a good result. I don't know the reason.
January 24, 2006, 06:36 |
What was the % error in your study comparing to the literature?
January 24, 2006, 11:07 |
RSM model gives about half of the empirical formula's result.
Display Modes | |
Look for job, a CFD project using fluent! | roozy | FLUENT | 2 | April 20, 2010 01:28 |
which one? FLUENT, Star-CD or CFX? | M. Amin | CFX | 2 | February 14, 2004 00:21 |
which one? FLUENT, Star-CD or CFX? | M. Amin | FLUENT | 6 | February 9, 2004 03:45 |
which one? FLUENT, Star-CD or CFX | M. Amin | Main CFD Forum | 1 | February 8, 2004 20:52 |
I wanna have FLUENT | aditya | FLUENT | 2 | January 29, 2004 19:43 |
