January 25, 2006, 07:54 |
Startup Problem in Gambit 2.2 with WindowXP
Dear ALL, When I run on my PC using WindowXP,I meet following problem shwing in "Gambit Startup".
[ Gambit failed in locating Exceed installation on your system. Please try to start Exceed manually before you run Gambit. Cannot open connect stream. TRANS(SocketINETGetAddr): tnamebysocket() failed TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed TRANS(Open): transport open failed for tcp/SSCR-E4:0 Unable to open display ] Please let me know how I should do. |
January 25, 2006, 08:03 |
Re: Startup Problem in Gambit 2.2 with WindowXP
You need to have exceed already installed on your pc in order to run Gambit.
January 25, 2006, 09:59 |
Thank you HVN
Can I get free download Exceed?Can Gambit run during disconnection of server? |
January 25, 2006, 11:09 |
You could download exceed on the fluent user website or ask a Fluent representative to send you the exceed cdrom.
You need to be connect to the license server to run Gambit |
Gambit Startup Window | Jay Shim | FLUENT | 2 | February 12, 2015 14:05 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
gambit startup problem | coolprudhvi | ANSYS Meshing & Geometry | 0 | July 1, 2011 02:34 |
Gambit startup options | PAD | FLUENT | 0 | July 21, 2006 05:38 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
