Unit in UDF
Old   January 24, 2006, 22:02
Default Unit in UDF
Tajul
hi everyone, I am working with micro channel flow. Let the height of the geometry of my channel is 1.2 micro meter. I know I have to convert this unit to meter by scale conversion. But when I will write UDF then if I have to use the value of height then I to write H=1.2 or H=0.0000012? Thank you. Tajul
Old   January 25, 2006, 02:29
Default Re: Unit in UDF
Laika
All the values our UDF communicates with the Fluent solver must be in SI units. If you retrieve a value from Fluent, it will be in SI unite, and if you give a value to Fluent, it will be interpreted as it wee in SI units.
Internally, Fluent always uses SI units. Even if the GUI is set to use PSI for pressure, all the values will be translated into Pa. Such a translator does not exist between your UDF and the solver.
best regards,
Laika, still orbiting
Old   January 25, 2006, 21:04
Tajul
Dear Laika, Thank you for your valuable suggestions. You are right but I am in problem whenever I use SI unit for channel height. I am explaining this in my next message. With best wishes to you Tajul
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF unit and FLUENT output saifulraju FLUENT 4 September 21, 2010 22:22
Control dynamic mesh with different length unit by UDF nchuche FLUENT 1 June 29, 2010 10:33
Unit of UDF AdN FLUENT 0 May 2, 2006 09:04
