-   -   axisymetric (http://www.cfd-online.com/Forums/fluent/39426-axisymetric.html)
BB January 27, 2006 16:45
axisymetric
Hello, I am using 2d fluent for simulating a rotating pipe. Like in fluent tutorial (vof) I used axisymetric model which is rotating. But that way it is only possible to export x and y component of velocity. However if the model is rotating there should be also z component. Am I wrong, is it possible to export it somehow?
regards
kharicha January 28, 2006 04:06
Re: axisymetric
Use 2D Axisymmetric "SWIRL" in the solver, not only 2D Axisymmetric....
so have a look in you settings...
bb January 30, 2006 14:49
Re: axisymetric
Thanks, I already did that. So, when exporting, swirl velocitiy component is actually z component?
BB.
kharicha January 31, 2006 03:07
Re: axisymetric
Yes, you are right:
Fluent components->radial components
x -> z component
y -> r component
z -> theta component (C_W or C_SWIRL)
So in gambit your geometry should have its rotating axis on the x axis. be carefull on that....
BB February 1, 2006 04:43
Re: axisymetric
Thanx!!! That helped!!
