Home > Forums > FLUENT
Help: File Transfer from windows to Linux
Old   February 1, 2006, 19:58
Default Help: File Transfer from windows to Linux
Ravi Doddas
Hi all
I seem to have a problem with file transfers from one platform to another. While I work on Gambit locally (using my own software on my PC), I tried to export the mesh to a server on which FIDAP was installed. This server runs on a Linux platform and doesnt recognize my FDNEUT files and meshes. Is it because of the OS mismatch? Is there any solution to this?
Ravi
Old   February 1, 2006, 22:21
Default Re: Help: File Transfer from windows to Linux
Ynot
what's the error message?
Old   February 2, 2006, 00:59
Ravi Doddas
Theres no official error message as such. FIDAP simply says the process(of running the file) has ended. When I go and check my FIPREP file that I input to Fidap from the command prompt window, I see large portins of blank areas where it was supposed to have shown by entity specifications and the input pressure and velocity conditions. This is what made me believe that there might be an OS mismatch happening in between.
Old   February 2, 2006, 03:57
edi
Have you transfered your file in binary form? I had similar problems when trying to put my files from windows to unix in ascii mode. Switched to binary and solved the problem.
Hope this helps
Edi.
Thread Tools
Trackbacks are On
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 15:49
