Home > Forums > FLUENT
Mixing tanks
Old   February 2, 2006, 04:48
Default Mixing tanks
Ana
I need some help with a simulation of a mixing tank. It is a mixing tank with some wall jets on one side and there is a hole in the bottom of the tank. I have used k-e and RSM for the simulations but the model does not agree with the experimental data. It does not spin around the hole as observed in the experimental. Any idea of how I can change the model for simulating correctly this swirling flow around the hole.
Thanks a lot
Ana
Old   February 2, 2006, 04:52
Default Re: Mixing tanks
HVN
Is your mesh enough fine around the hole?
Old   February 2, 2006, 05:03
Ana
Yes I think so, although I can try to refine it more around the hole. The main problem is that water flow almost directly towards the hole instead of swirling around it, as I measured during the experimental work. I was thinking that maybe I should change the bc at the outlet. Any idea?
Thanks a lot!!!
Ana
Old   February 2, 2006, 11:07
HVN
When you compute some pathlines, what do you see?
Thread Tools
Trackbacks are On
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 14:31
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 18:08
problem with MFR model for multiphase mixing tanks Srinivas Main CFD Forum 1 November 7, 2005 15:16
IS ANY ONE USING MixSim Package for mixing tanks Srinivas FLUENT 0 October 18, 2005 02:11
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 08:16
