Check this UDF,please.
Old   February 2, 2006, 11:20
Default Check this UDF,please.
Josh
Can anyone check what's wrong with this UDF. When I interpreted it with FLUENT, a syntax error was reported in the third line.
#include "udf.h" #define QM 5e-6 DEFINE_SOURCE(charge_density,c,t,dS,eqn) { real charge_density; cell_t c; charge_density=C_R(c,t)*QM; return charge-density; }
Old   February 2, 2006, 13:42
Default Re: Check this UDF,please.
Markus
Hi Josh
You don't have to declare cell_t c explicitly in your udf as it is already passed to DEFINE_SOURCE. Maybe this redefinition causes the problem. Max
Old   February 2, 2006, 14:02
Default Thank you. *NM*
Josh
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Cell check and Boundary check errors AB Siemens 4 October 28, 2004 13:04
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 03:10
