February 4, 2006, 19:35 |
Modeling Unsteady Velocity
I have an unsteady velocity waveform that I want to hook up to Fluent. How do I set the criteria for the number of iterations per time step, the number of time steps, and the value of the time step? On what criteria are these based? Also, is it possible to hook the entire flow waveform from some data acquisition software like Windaq to Fluent? I'm relatively new working with Fluent and so I would greatly appreciate it if someone could offer me a detailed explanation. I couldn't understand too much from the tutorials and hence I ask. Thanks in advance. Regards, Vidya |
February 4, 2006, 22:53 |
Re: Modeling Unsteady Velocity
I do not think u shud worry abt such parameters, usually 500 iterations are chosen for the solution to converge. The value entirely depends on when the solution gets converged. Increase the number of iterations if solution does not converge in the given 500 iterations.
February 4, 2006, 23:28 |
Yeah, but how do I set the value of the time step?
Vidya |
February 5, 2006, 14:40 |
In unsteady formulation size of time step and no of time stepes are important.it depends on what solution algorithm u have used like implicit or explicit,it also depends on the physical nature of ur problem like subsonic , supersonic, turbulance etc... The size of time step should be the one order less than ur minimum time scale in ur problem. size of time scale should be smaller for explicit than implicit. it will keep ur iteration stable. For no of time step u start with 100, i dont know ur problem so i cant tell the exact. try to get steady state solution. I hope this will help u,
February 5, 2006, 15:56 |
Hi Balmiki,
Thanks a lot for the reply. I'm trying to model the blood flow in a human vein. So the flow is laminar and I'm using first order implicit formulation. I also want to try the secong order formulation. So based on this information, how do I go about fixing the size of the time step and the number of time steps? Thanks, once again. Vidya |
February 6, 2006, 01:08 |
If you know from experience or by another source the period of your wave T0, start with DT=T0/10...and see how your system behaves....
A second order formulation in space and in time might be necessary to get accurate results.... |
Unsteady Flow Modeling in Flow3D | flow3d_399 | FLOW-3D | 6 | August 13, 2009 22:34 |
Unsteady velocity magnitude- DNS | Rohan | FLUENT | 0 | May 19, 2008 16:07 |
Unsteady Physiological Velocity Inlet | Taewon | FLUENT | 0 | March 9, 2008 18:32 |
Velocity Under-relaxation in SIMPLE type methods | Matt U. | Main CFD Forum | 6 | July 4, 2005 05:29 |
Unsteady Velocity - UDF in parallel | Prateep Chatterjee | FLUENT | 4 | November 23, 2001 04:40 |
