easy settings of camara position
Old   February 6, 2006, 07:21
Default easy settings of camara position
Ralf Schmidt
Hi!
Is there a possibility, to set the camara on excactly the same position for different geometries (postprocessing)??
Like a standard view.... could it be done with a journal file?? But isn't it to complicated?
Now, I write down the settings in the camara panel and apply the same for other geometries... for to much work
Any better Idea?
Ralf
Old   February 6, 2006, 09:03
Default Re: easy settings of camara position
Jason
In the views menu you have the option to save the views in your current model. You also have the option to write your views to a file which can then be read into other models.
Orientate the view the way you want it, then go to Display->Views. Give it a name in the "Save Name" block and then click "Save". This will save this view in your current model and you'll always be able to go back to this view by going back to Display->Views and double clicking the name of the view in the "Views" block. Then you can select "Write" and select which views you want to write and give it a file name. Then in another model you can click "Read" and you can read in the views that you saved.
Hope this helps, and good luck, Jason
Force dependent on particle position jranita OpenFOAM Programming & Development 1 August 23, 2011 19:44
how to read in a position file jiejie OpenFOAM 0 May 23, 2011 04:38
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
a way to make lots of money quick and easy no lies Dob Main CFD Forum 0 October 10, 2006 16:45
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
