our of memory in meshing
Old   February 8, 2006, 12:16
Default our of memory in meshing
BAOYU
I am doing mesh using gambit. Everything works fantastic except one. You know, I am doing parameteric programming. After every round of the "DO LOOP", gambit will eat 4 more Megabite memory (I let the program run, at the same time open windows XP task manager and go to memory tab to see memory information). So after about 500 cases calculated, gambit will eventually report the error of "out of memory". I already deleted the meshes and geometries after every round (using "reset" command). I also tried using the "identifier" command in the innerest DO LOOP. But after this command, every variable is gone.
IS there any way to solve this problem? Thank you very much! BTW, the input file is in the attachment.
In GAMBIT meshing, Out of Memory! ? Conan FLUENT 7 November 10, 2008 04:02
3d Gambit meshing shows out of memory tamjid FLUENT 3 September 27, 2008 01:01
Gambit 3D Meshing: Error: Out of Memory Sucho FLUENT 1 May 2, 2007 07:13
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
out of memory while meshing Rahul FLUENT 2 December 31, 2003 04:25
