February 20, 2006, 02:00 |
channel flow help
Dears Hi everyone. I want to simulate a two dimensional microchannel flow (1.2 micron by 3000 micron)by fluent. case1. The inlet pressure is 272260 pa and outlet pressure 100800 pa. case2. Inlet pressure 135072pa, outlet pressure 100800 pa. In both the cases no slip condition, one side is wall and another side is symmetry wall boundary. Flow is compressible.Isothermal condition of temperature 314k. Density should be calculated by ideal gas law. I tried but it did not converge. can anyone help me how to simulate it. I will highly appreciate. Tajul
February 20, 2006, 07:34 |
Re: channel flow help
post your mesh file on your web site and post a link so I can download it
February 20, 2006, 07:51 |
Thank you for your response. Sorry, I do not know the process you said. If you kindly send me your email address I can send the mesh file to you.
February 22, 2006, 19:02 |
1- What unit have you used in constructing your grid? 2- Have you checked the knudson number based on the cell dimensions?
February 22, 2006, 20:23 |
I used micrometer but converted to meter when I run fluent. In the floowing cases I used SI units where necessary. The inlet pressure 135072pa and outlet 100800pa. I calculated analytically as follows at the inlet. specific heat ratio=1.4 mach number=0.66 gas constant=296.8 speed of sound=361.21 inlet velocity=238.53 Reynolds number=9.43 Knudsen number=0.1038
Display Modes | |
wallHeatFlux for heated walls in laminar channel flow | svens | OpenFOAM Post-Processing | 0 | June 20, 2009 20:33 |
Channel flow set up | Jung | Main CFD Forum | 2 | November 21, 2007 06:51 |
The initial condition for turbulence channel flow | Ma Jianfeng | Main CFD Forum | 1 | April 20, 2005 03:50 |
Stabilizing turbulence equation in channel flow | Biga | Main CFD Forum | 5 | March 22, 2005 20:06 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
