Home > Forums > FLUENT
guary as quickly as possible
Old   February 15, 2006, 13:20
Default guary as quickly as possible
siht
please help me if u can how to model the natural convection using fluent thanks alot in advance sihu
Old   February 15, 2006, 22:23
Default Re: guary as quickly as possible
Seyed Farid Hosseinizadeh
Hey Man:
My work is exactly in this situation. what do you want to know?
Best Regards, Farid,
Old   February 16, 2006, 08:30
siht
i want to model flow and heat transfer inside rectangular channel and my fluid properties is like water properties and i have the small temperature difference so i want to modell considering the buoyncy or the natural convection using fluent i hope u help thanks alot in advance Mr Syed
Old   February 16, 2006, 14:19
Hey man Please send me your grid and say me exactly what's your problem. The mixed convection or Natural convection? What is your Rayliegh number? at the end what is your Prandtl number? Best Regards, Farid,
Old   February 16, 2006, 15:02
siht
i use to model mixed convection density=996 kg/m3,thermal conductivity=0.61 W/mk and specific heat=4184 J/kgk , viscosity = 0.00088 kg/ms and the velocity=0.0073 m/sec and temperature difference is 15k and the geometry is rectangular 400mm*40mm*200mm this is the data thanks in advance brathor Syed Fareed and i wait for ur help
Old   February 18, 2006, 02:18
Hey Man, Please you must activate in "operating condition" the "gravity". Then enter the gravity (0. for x direction,-9.8 for y directin, 0 for z direction). I assumed the y direction is parallel to gravity direction. Then in "Materials" select "Boussinesq" option in "density". By selecting this option your density changes to zero that you must enter 1.225. After that in this window at the bottom by moving your mouse you must enter the value of "Thermal Expansion". by this works the fluent run the test case for free convection. I hope that works. At the end as you know your problem is mixed convection and you must set the Rayliegh number (or Grashohph number), Prandtl number and Reynolds number. I mean you must be careful to enter the all properties in the material section and velocity inlet value. If you have any problem please contact me.
Have a good weekend, Best Regards, Farid,
Old   February 18, 2006, 12:15
siht
iam trying but the solution does not converge and i have strange velocity profile and i got high temperaure so please send me in my e mail the explanation in detail thanks very much Syed Farid Hossain e mail sihatt2002@yahoo.com thanks again for your attention
Thread Tools
Trackbacks are On
please help quickly siht FLUENT 4 February 14, 2006 12:30
Is there any way to quickly export ascii file? HVAC FLUENT 0 December 29, 2005 21:24
P-Mass residual convergers very quickly M CFX 2 October 18, 2005 23:56
How to put quickly a velocity profile in a table? Stephane bone CD-adapco 5 March 8, 2005 11:45
Reference Pressure-Need help quickly Ben CD-adapco 2 July 23, 2004 09:24
