Diffusion in laminar flow
Old   February 15, 2006, 16:28
Default Diffusion in laminar flow
Neha Rao
I have a 2 inlet device that I am trying to simulate laminar flow for. I will be sending in two different coloured dyes at the same velocities through the 2 inlets. I want to be able to simulate and show (display) the interaction (diffusion) between the 2 fluids using Fluent. What model do I use? The species transport model? And is it possible to have a velocity vector/contour display with 1 color for 1 dye,and another color for the other dye?
Old   February 16, 2006, 02:46
Default Re: Diffusion in laminar flow
balmiki
hi u can use species transport model.
Old   February 16, 2006, 13:24
Neha Rao
Thanks for your message balmiki. I used the species transport model. But I still don't know how to be able to get a picture of the 2 fluids in 2 different colors. What display option should I use? Please let me know. Thanks again!
Old   February 16, 2006, 14:40
balmiki
hi, since u r using 2 diffrent fluid it will automatically appear in 2 different color u dont have to do any thing. what exactly u want to display ?
Old   February 20, 2006, 13:47
Neha Rao
I want to display the velocity vectors of the 2 fluids in 2 different colors. For a single fluid, as you must be aware, the velocity vectors are color coded..so the areas with faster flow have red velocity vectors, and the ones with slower flow have blue velocity vectors. How do I get just velocity vectors-without any color coding, to have a single color for each fluid?
Flow over 2D Cylinder, Laminar and Turbulent Tsr63 FLUENT 5 November 13, 2014 12:13
Can I use turbulent model to solve a laminar flow? nikhil FLUENT 5 February 1, 2011 10:42
Convergence of laminar flow model for high Re Chander Main CFD Forum 0 December 16, 2010 05:10
How to enforce laminar flow while using k-e Grzegorz Kondora FLUENT 0 January 28, 2009 10:35
grid for laminar flow kim FLUENT 2 April 4, 2002 02:44
