June 29, 2017, 10:45 |
Particle deposition in DPM simulations
shanth
Rep Power: 9 |
Hello everyone,
I have been scouring the web for weeks now and haven't been able to get a solution for this. I am running a transient simulation wherein I inject small water droplets (10 micron) into the flow from the inlet. The geometry is complex with a pipe splitting to many branches. I have set the wall boundary condition to trap the particles. All well and good. Now my dilemma is how exactly do I postprocess this information. I would like to display the accumulation of particles on the walls as a function of time.. Nothing that I have tried so far gives anything close to this. I have even tried the accretion option to display contours, but this doesn't really show what I am after. Any help and guidance is appreciated! Thanks! |
December 27, 2017, 16:13 |
Shyam
Rep Power: 8 |
Hi there,
Just wondering if you had any luck with this? I am trying to do something similar at the moment? |
December 28, 2017, 05:31 |
Kushal Puri
Rep Power: 12 |
I hope you had run one iteration after turning on the acceration option, if yes then, i think u will get what you are trying to display
December 28, 2017, 06:00 |
yun
Rep Power: 10 |
hi,
i am not 100% sure but i think you should adjust the monitor section before the run for this purpose. you need the create surface monitor. area-weighted-average, DPM-DPM concentration etc.. hope this helps! |
December 31, 2017, 09:17 |
shanth
Rep Power: 9 |
Thanks for the replies.. I found the closest answer to my question in this post
particle deposition-show the trapped particle Hope it helps others as well. |
December 31, 2017, 09:18 |
#6 | |
shanth
Rep Power: 9 |
December 31, 2017, 12:41 |
#7 | |
Shyam
Rep Power: 8 |
dpm, fluent, particle, trap |
DPM UDF trapped particle deposition | barzin | Fluent UDF and Scheme Programming | 0 | September 4, 2012 10:27 |
In steady DPM model, how to get a particle residence time in a specific cell? | DanK | FLUENT | 1 | August 25, 2012 00:33 |
Particle position in DPM | moloykb | FLUENT | 0 | March 14, 2012 00:27 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
About Particle velocity of DPM in Fluent? | long zhengwei | FLUENT | 0 | March 13, 2009 04:02 |
