Home > Forums > FLUENT
pls help me, Mr Zxaar
Old   February 18, 2006, 22:48
Default pls help me, Mr Zxaar
emir
Dear Sir,
I did simulation on combustion of wood.. Wood length is 100cm x 5cm x 2cm(experimentally). it'is non-premixed and i used prePDF.
I did use DPM where: 1. the wood particle(combusting particle) is injected from surface.how do i define the particle diameter? 2. i define the moisture content of wood as water-liquid (droplet particle) and also injected from the same surface as the wood particle.is this possible?
i have questions too on prepdf: 1. when i display my pdf table, the graph shape seem to converge (i mean did not touch the x-axis). does this will affect my result in fluent? i've tried reduced my LHV value and the graph shape keep going down but this will not the real LHV as calculated according to C,H,O,N value.
highly appreciated of your advice or comments.TQ.
Regards, emir
Thread Tools
Trackbacks are On
help me understand porous media in fluent~ pls pls.. :( naftalena FLUENT 0 February 28, 2010 13:20
i need help following problem pls pls help gmani CFX 4 March 31, 2009 09:39
gambit "pls help me" chandra sekhar b Main CFD Forum 1 November 17, 2008 12:47
multi phase flows....pls help... karthik FLUENT 0 November 16, 2005 10:15
help pls gianluca FLUENT 2 November 12, 2004 11:27
