-   -   why it doesn`t change (http://www.cfd-online.com/Forums/fluent/39709-why-doesn-t-change.html)
grzesiek February 19, 2006 05:26
hi i trying to heat a tank filled with water. boudary condition: bottom wall temperature 500K, water temperature 300K, pressure of water 1013hPa. Iterations doing well, residuals too but after iterations density doesn`t change. Why. In real density of water change with temperature isn`t ? so why it doesn`t change in my model. Im using: unstady, VOF with body implict..., g=9.81m2/s. time step size 0,001s, number of time steps 100000 regards
Kharicha February 21, 2006 03:43
Re: why it doesn`t change
You have to explicitly include the density function of temperature ...in the material data.....
Fluent will not change it if you use a fixed density!!
grzes February 21, 2006 06:58
Ok Thank you. I`ve already made an UDF and now everything seems to be ok. regards Grzesiek PS. Mabby you know what to do to have a specific heat changes with temperature changes. I`ve heard that "cp" is the only properties which can not be defined by UDF and must be constant. But what to do when it is a function of temperature and concentration ?
Kharicha February 22, 2006 02:59
Well you are right, it is strange that C_p cannot be modified with an UDF...
but you can use a piecewise-linear function of temperature...or polynomial function of temperature....I am sure you can find what you need
