-   -   UDF Compiling error LNK1181 (http://www.cfd-online.com/Forums/fluent/39729-udf-compiling-error-lnk1181.html)
marion February 20, 2006 13:33
When I try to compile a udf in Fluent, I get a fatal error LNK1181. Here is the transcript of the message:
LINK: fatal error LNK1181: cannot open input file "fl6216s.lib"
Apparently, I don't have the right linker version. I have V3.00.5270 whereas I should have Version 6.00.8447 (from the installation FAQ fluent website).
I tried to install the latest Service Package for Visual C++, as it is recommended on Fluent's website, but it still gives the same error.
Does anyone have an idea of what to do to fix that problem? How can I get the right version for the linker?
Thank you,
Marion.
turbomachinery February 21, 2006 00:04
Re: UDF Compiling error LNK1181
Hi, when you install the Visual C++, you must add the environment variables at the same time of installing. your problem is led by the wrong environment variables or you didn't add any Environment_variables.
marion February 21, 2006 04:07
I have checked the environmental variables again, and they are as they say they should be on Fluent Website. http://www.fluentusers.com/support/i.../udfguides.htm
Thanks for your help.
