February 19, 2006, 04:26 |
why it doesn`t change
hi i trying to heat a tank filled with water. boudary condition: bottom wall temperature 500K, water temperature 300K, pressure of water 1013hPa. Iterations doing well, residuals too but after iterations density doesn`t change. Why. In real density of water change with temperature isn`t ? so why it doesn`t change in my model. Im using: unstady, VOF with body implict..., g=9.81m2/s. time step size 0,001s, number of time steps 100000 regards
February 21, 2006, 02:43 |
Re: why it doesn`t change
You have to explicitly include the density function of temperature ...in the material data.....
Fluent will not change it if you use a fixed density!! |
February 21, 2006, 05:58 |
Ok Thank you. I`ve already made an UDF and now everything seems to be ok. regards Grzesiek PS. Mabby you know what to do to have a specific heat changes with temperature changes. I`ve heard that "cp" is the only properties which can not be defined by UDF and must be constant. But what to do when it is a function of temperature and concentration ?
February 22, 2006, 01:59 |
Well you are right, it is strange that C_p cannot be modified with an UDF...
but you can use a piecewise-linear function of temperature...or polynomial function of temperature....I am sure you can find what you need |
How to change density in OpenFoam | zhaowei | OpenFOAM Running, Solving & CFD | 8 | November 5, 2018 10:37 |
Solid/liquid phase change | fabian_roesler | OpenFOAM | 10 | December 24, 2012 06:37 |
Change cell zone index/thread during simulation | neilduffy1024 | FLUENT | 0 | January 17, 2011 09:40 |
no enthalpy change across the momentum source | Atit Koonsrisuk | CFX | 2 | December 19, 2005 02:33 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
