-   -   Can't figure which cell particle is going to -- AB (http://www.cfd-online.com/Forums/fluent/39762-cant-figure-cell-particle-going-ab.html)
am February 21, 2006 19:13
Dear All,
I'd never seen this msg."Can't figure which cell particle is going to -- ABORT" .Anyone have any ideas what's the reason?
I injected fuel and moisture on the same (plane+bounded) surface.I'd run the same method like this before but the difference is at first case, i've created the surface in the gambit and set it as a wall in BC. Then, i injected the fuel and moisture from the plane.
I would like to hear any advice/suggestion.Thanks in advance.
-Am-
