Derek
February 24, 2006 12:54 |
Mass diffusion of surface exposed to water flow
I'm modeling a fairly simple scenerio in Fluent. I have a rectangular channel (55mm x 2mm x 4mm LxWxH). Along one wall (4mm) I have a dissolvable tablet (4mm x 2mm LxH). Water is the fluid flowing thru the channel. There is no chemical reaction between the solid and the water, only dissolution. In setting up the species transport, do I select water as the "Selected species" and the solid as the "selected solid species?" This is assuming I'm using wall surface reaction model. I'm fine with setting material properties and boundary conditions, however my final question is how to make my fluid water (under boundary conditions)?? It has been defaulting to air (I believe) and I have been unable to change it to water. Do I need to specify my inlet condition mass fraction as 100% water? Or is there another way? Thanks in advance
