Dynamic mesh-without UDF/Profile
Old   February 17, 2006, 00:14
Default Dynamic mesh-without UDF/Profile
Rajesh
Hi all,
In a dyanmic mesh problem, is it possible to assign a rigid body motion without the use of UDF/Profile fns? i.e, can the motion of the rigid body be determined by the flow itself? For example, a high pressure gas expanding behind a moving piston, in which the forward motion of the piston is due only to the gas pressure behind it.
thanks for reading
Rajesh
Old   February 17, 2006, 02:17
Default Re: Dynamic mesh-without UDF/Profile
mAx
UDF! you habe to decribe the motion of your piston due to the pressure force. That's mean the UDF should inttegrate twice the pressure force on your body to determine the motion at each time step. Take a look at MDM tutorial. The UDF described, is exactly what you need. Hope it helps.
Old   February 17, 2006, 02:45
Rajesh
Dear Max,
Thanx for your reply.
Does that mean fluent is unable to calculate the motion of a piston by the expanding gas behind it without any user input?
For example, suppose, I have a high pressure zone and a low pressure zone initially separated by a wall, and the piston is kept in the low pressure zone. If I remove the wall, then the gas expansion will move the piston forward. The motion of the piston is decided by the pressure difference across it and the mass of the piston.
Am I not able to model the phenomina without the help of a UDF? It seems stange to me(...may be due to my inexperience!), as while writng a udf, we have to give the pressure force acting on the piston at each instant, as you told, and this force is decided implicitely by the veolcity of the piston at that instant, while the latter is decided by the pressure force. Thus the velocity and pressure force are coupled at any inastant. In such a case we cannot calculate the pressure force unless we analytically solve the equation of motion of the piston( I think, I have made it clear!)
BW: What's MDM?
thanx for reading
regards, Rajesh
Old   February 17, 2006, 03:30
mAx
MDM is for Moving Deforming Mesh. As long as your piston will move, you must have a deforming Mesh (Layering, Remeshing or Smooting). In The MDM Panel, you have to define moving walls, deforming walls and stationnary walls. For the Moving wall, eg: Rigid Body, the motion has to be decribed, either with a Profile (that means that the motion is already known, can be also deescribed with a UDF) or with a UDF (that means that the motion will be calculated, in your cas with the integration of the pressure force: at each time step: F=ma -> a=dv/dt=F/m -> dv=F/m.dt -> dx/dt= dv -> dx = dv.dt)
Old   February 17, 2006, 03:50
Rajesh
Thank you very much mAx
I will have a look at the UDF manual and try to figure out my problem.
Thanx for reading
regards,
Rajesh
Old   February 17, 2006, 04:05
mAx
I work with this UDF in my applications: valve-spool wich moves under pressure force and spring effects.
Old   February 17, 2006, 04:59
Rajesh
Hi mAx,
That's nice to hear. This is the first time I trying to do a problem with the use of UDF. So please don't mind if I bother you with my silly doubts!
Thank you very much,
regards,
Rajesh
Old   February 17, 2006, 05:33
mAx
no problem. this forum is exactly for that.
Old   February 26, 2006, 11:41
yilmms
Hi Max, I'm working about compressible(density=idealgas) incylinder3d problem. 3000rpm,staring angle=180 finish angle=720 anglestep=0.5. when preview mesh no problem. but when ı give pressure inlet-pressure outlet and starting iteration continuity gets bad results and crash 250 degre. I change anglestep,iteration per time step,mesh size but every time it crash neary 250-255.I try all k-e k-o reynolds all models but it only change 240 to 245. whats the problem? please give me some advise...
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 2 May 7, 2020 10:42
Incylinder dynamic mesh with volumetric reaction mas FLUENT 4 May 3, 2012 10:22
dynamic mesh on a hexa grid Manoj Kumar FLUENT 0 August 21, 2007 07:41
Dynamic mesh + grid adapt = Crash! (Files included BillH FLUENT 4 July 24, 2007 15:31
