February 27, 2006, 22:10 |
looking for help for ICEPAK model
Hello, All,
The ICEPAK model contains several THIN PLATES with 2 mm effective thickness. As you know, THICK PLATE in ICEPAK have thickness option and the thickness will extends in either the positive or the negative coordinate direction (normal to the plane of the plate),depending on whether the thickness is specified as a positive or negative value. My question is if the positive or negative value of effective thickness of THIN PLATE has the same meanings as that of THICK PLATE. If not, which direction can be expected to extend for THIN PLATE? Best regards and Thanks in advance, aneshe |
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 04:41 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
Grid resolution for full-scale and down scaled model | gravis | Main CFD Forum | 0 | October 2, 2009 10:27 |
