-   -   simulation with ideal gas material properties (http://www.cfd-online.com/Forums/fluent/39877-simulation-ideal-gas-material-properties.html)
Ana February 28, 2006 08:03
Hi, i am simulating the airflow over a diffusor in the compressor of a turbocharger with fluent 3d.
I select the option density =ideal gas in material properties, and i dont know how to initialize the problem.
I have the following boundary conditions:inlet massflow, and the outlet pressure.
I already tried to initialize with both, massflow and pressure outlet, with pressureoutlet and introducing my own values. I always get this error:
divergence detected in AMG solver
If i use the constant density model i dont find any problem.
if anyone can help me, i would thank you
Ana February 28, 2006 08:04
Re: simulation with ideal gas material properties
the error was divergence of temperature. Sorry
kafka February 28, 2006 08:17
Usually when dealing with ideal gas, I initially disable the energy equation in Solve/Controls/Solution. Once the problem tends to converge, I enable the energy again. This procedure is also recommended in the Fluent manual and it works most of the time.
Chris Bailey March 1, 2006 17:27
I have had a similar problem and substituted my own polynomials for the gas properties, which eliminated the divergence error. Also, for some reason I don't understand (and have a request in to tech support for), Fluent's model for air seems to give half the conductivity and 1/3 the specific heat that it should.
