Superheat Steam in FLUENT?
Hi, Is there a possibility in FLUENT to handle superheat steam? if yes, how does it calculate different states along a expnasion line of a turbine.Thanks
Re: Superheat Steam in FLUENT?
you can treat super heated steam as ideal gas. if not so please tell me why?
Why don't you use the properties that are available with the non-equilbrium steam condensation model? I think these are based on a real equation of state for steam.
I neeed help with super heated steam in a channel
hello my dear friends I want to use super heated steam in fluent as working fluid in a channel, how is it possible, i really need someone to help me
Fluent supports refprop (a NIST database) which has superheated steam. You simply need to activate it through the TUI. It's very easy to use. Refprop uses a Helmholtz equation of state, a true multi-parameter equation of state, and in my opinion is the most accurate generalized database available beyond localized measurements. |
thank you LuckyTran for your prompt response:
I activated it by using : define/user-defined/real-gas/nist-real-gas-model then I choose "water.fld" in order to activate this for super heated steam, but the result i get is absurd what about using water vapor in fluent data base? it won't be useful? |
