Dynamic Meshing: Error: open_udf_library
Old   March 1, 2006, 07:46
Default Dynamic Meshing: Error: open_udf_library
HS
Hi there,
I believe that similar topics have been posted before, but I'm still pretty confused.
FLUENT has been set up on a Windows XP based PC. The administrator has instaled Visual Studio too.
I'm tryiong to run a dynamic mesh problem, where I need to click on my source file via Define-> Functions-> Compiled-> . Building it is fine. However, when I try to load the udf, I get the Error: open_udf_library error message, and I can't understand why. This PC is not connected to a cluster. It is stand-alone.
I tried to specify the path of my libudf to my directory where my case and data files are located, but I still get this message. Can anybody please advise? Thanks so much!
HS.
Old   March 1, 2006, 07:59
Default Re: Dynamic Meshing: Error: open_udf_library
mAx
check if an libudf isn t already loaded. Functions-> Manage. If yes, then unload it, and re-do Functions-> Compiled
dynamic meshing pronik_zoro ANSYS Meshing & Geometry 0 March 12, 2011 11:01
Dynamic meshing Manoj Kumar FLUENT 3 June 27, 2010 19:26
[GAMBIT] Dynamic Meshing of a combustion chamber donarundas ANSYS Meshing & Geometry 1 December 2, 2009 07:13
Issues with dynamic meshing sridhu88 FLUENT 1 June 11, 2009 16:46
dynamic meshing option arehman Main CFD Forum 4 June 27, 2004 02:55
