Urgent-Problem in UDF
Old   March 2, 2006, 11:01
Default Urgent-Problem in UDF
Josh
I am using a user defined scalar transport equation (UDS) in which the SOURCE term is defined by the macro DEFINE_SOURCE (name, c, t, dS, eqn).
In this macro, I need to calculate the diameters of all the particles in a cell which can be calculated in discrete phase model (DPM) as P_DIAM (p).
Since the Tracked_particle pointer p is not an argument in DEFINE_SOURCE (name, c, t, dS, eqn), it can not be recognized if P_DIAM (p) is directly used.
How can I get the particle diameter in a cell when using DEFINE_SOURCE (name, c, t, dS, eqn)? Is there any other parameter in FLUENT which stands for the particle diameters in a cell?
Old   March 2, 2006, 11:15
Default Re: Urgent-Problem in UDF
RoM
There is no easy way to access particle diameters during fluid iterations. Diameters are not stored in cells because fluent does not need them for fluid iterations. If you need the diameters you will have to write an additional udf which stores the needed diameters in user defined memories for later access. This has to be done during the particle tracking.
Another option would be to calculate the UDS source term during the particle tracking, store it in an UDM and retrieve it later.
Good Luck, RoM
Old   March 2, 2006, 11:35
Josh
Thank you very much! Your suggestions are very constructive. I have to make a try even though it is hard for me.
Josh
Old   March 2, 2006, 15:54
Lourival
Another way, you could do something with the MACRO: DEFINE_DPM_SCALAR_UPDATE as is in the example of the same macro.
You can try, post the results and erros...
Lourival
Old   March 2, 2006, 23:01
Josh
Thank you very much for your suggestion. I will try this as well.
Josh
UDF Problem ozgur Fluent UDF and Scheme Programming 18 January 17, 2016 14:40
Pressure profile UDF for unsteady-state problem? Mohsen Keshavarzian FLUENT 2 August 20, 2008 04:22
parallel UDF problem kerem FLUENT 2 June 20, 2006 06:56
Switch problem! using 2 custom udf laws at the same time HP FLUENT 0 September 15, 2004 09:48
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 10:22
