simulate flow over a cylinder
Old   February 28, 2006, 06:35
Default simulate flow over a cylinder
changkiang
hello, anyone is simulating (or has been simulated) flow past a cylinder? my averaged Cd(Re=1000~10000) is around 1.5 then much larger than that in experiment. by the way, my material is water, turbulent model LES, 35000 strctured grid in 20*40 mm computational domain.
any suggestion is appreciated in advance!
Old   February 28, 2006, 12:48
Default Re: simulate flow over a cylinder
se
In the Reynolds number quoted, the flow is turbulent with significant spanwise flow structures. You should use 3-D model.
Old   February 28, 2006, 15:15
MOHAMMED
well, you have a low Reynolds number so unsteady vortex shedding is expected. so you have to enable usteady solver and to have a fine mesh. using dynamic mesh adaptation will be useful. but i dont think that using 3d model will be a good idea, especially if you dont want to simulate the instability in the flow.
Old   February 28, 2006, 15:36
Ahmed
1- www.studentfluent.com 2- click on tutorial lib 3- tutorial 6 Flow past a circular Cylinder
Old   February 28, 2006, 15:48
onlooker
Thanks Ahmed!
Old   February 28, 2006, 23:02
changkiang
thank u man! the website is awfully helpful i believe.
Old   February 28, 2006, 23:17
changkiang
i agree with u,MOHAMMED. BUT, these is a problem, how to use dynamic mesh adaptaton? i'v ever done vortex induce vibration(VIV)and once used dynamic mesh, and i don't think they are the same.
THANX VERY MUCH!
Old   March 3, 2006, 17:13
Ahmed
That is nice. So be good and spread the word around, do not keep it for your selves. You can also use google to look for more sites with free tutorials
Old   March 3, 2006, 20:25
changkiang
i can not agree you more.
thanks again!
[Other] OpenFoam Flow over a Circular Cylinder WolfgangS. OpenFOAM Meshing & Mesh Conversion 12 March 3, 2014 10:53
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 17:51
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 10:05
Uniform Flow around a cylinder zhoubinwx OpenFOAM Running, Solving & CFD 44 March 31, 2009 10:50
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
