March 5, 2006, 10:43 |
marine propeller with sliding mesh
Hi ! I am simulating a marine propeller with the rudder blade, so : unsteady computation with sliding mesh. I made a cylinder interface around the propeller which separate the 2 fluid zones : "stator zone" and "rotor zone". The rotor fluid zone is a sliding mesh zone with the blade walls stationary. The computation looks good with evolutions of forces not too bad. My problem is about the path lines : they do not swirl enought for me !?? The mesh moves but it looks like the fluid does not move !! I don't understand....maybe I don't use correctly the sliding mesh.... Anyone can help me ?
Thanks. Thierry. |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Mesh grid a propeller with Gambit | vsun | ANSYS Meshing & Geometry | 0 | October 26, 2009 00:44 |
Gap produced in sliding mesh method | Lam | FLUENT | 0 | July 6, 2004 19:26 |
