Home > Forums > FLUENT
Error while exporting mesh
Old   March 4, 2006, 21:11
Default Error while exporting mesh
Vidya Raja
I have a solid model created in ProE. I imported it into GAMBIT and then created some additional edges and faces as an appendages to the original model i.e., the solid frame represents a frame and the additional appendages aere supposed to represent a flexible polymeric leaflet. This leaflet should be attched to the frame. But when I exported the mesh to Fluent, I got error messages saying that the faces of the leaflet that I created were not meshed and hence not exported.
Do I need to use the connect faces/ edges comand or is it understood by Gambit that the leaflet is attached to the frame because I used some of the edges of the frame also to make the connections? Can this be the reason for the error?
Please suggest something.
Thanks, Vidya
Thread Tools
Trackbacks are On
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
Gambit error in exporting mesh in 3D modeling Mazyar FLUENT 5 March 31, 2004 10:50
