How many UDFs can I specify at the same time?
Old   March 8, 2006, 16:21
Default How many UDFs can I specify at the same time?
Ynot
Hi guys,
I'd like to specify the three velocity components at a given boundary condition (radial, tangential, and axial). I tried to write a UDF for each velocity component, but i found out that Fluent only uses the UDF that was last interpreted.
Is there a way around this? Can I specify all velocity components in one UDF?
Much appreciated.
Old   March 8, 2006, 17:37
Default Re: How many UDFs can I specify at the same time?
Luca
write your UDF in a unique file. Luca
Old   March 8, 2006, 19:19
Ynot
do you have any idea how to dow that? F_PROFILE can't handle it. i need to specify the velocity in each direction (r, theta, z).
thanks
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
Time dependence UDFs. Emergency phanh Fluent UDF and Scheme Programming 6 March 3, 2011 04:35
