-   -   Can't create MPEG animation (http://www.cfd-online.com/Forums/fluent/40060-cant-create-mpeg-animation.html)
Jiri Novak March 9, 2006 10:11
Hi i have a problem with creating MPEG as animation playback in Fluent6.2.16 running under Suse Linux. I tried to store frames both in Metafile HMF and PPM image. Simply, as i click on "Write" MPEG the following error takes place:
CX_Hardcopy_Window: error opening PPM file
./sequence-1_5_000.ppm.
./sequence-1_5_001.ppm.
"|exec mpeg_encode /tmp/param52.93 2>&1" mpeg_encode: relocation error: mpeg_encode: symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link reference
Removing frame files ... done.
Thank a lot for any help with this Jiri Novak
ulwa March 14, 2006 04:34
Re: Can't create MPEG animation
Hi, I had a similar problem with mpeg_encode under SuSE 9.3. I solved it by replacing the mpeg_encode-program provided by Fluent with a newer version I downloaded from here: http://sourceforge.net/project/showf...ckage_id=26211
The mpeg_encode-homepage where you can download the source code is http://bmrc.berkeley.edu/frame/resea...eg_encode.html
Hope it helps.
Paola September 15, 2011 13:16
Hi all,
I have a similar problem. When I try to generate a mpeg movie from the .hmf files I get this error:
"|exec mpeg_encode  /tmp/param54.02 2>&1"
mpeg_encode: relocation error: mpeg_encode: symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
The .ppm files are actually created, but it is not able to create a mpeg.
I installed this http://sourceforge.net/project/showf...ckage_id=26211 (even if I have no idea of what I was installing), but it is not a solution so far.
Any suggestions??? Pleeease
H.Rahnama July 6, 2012 04:47
Having problem to creat MPEG!!!
Someone help please!
I am getting crazy with this!..................
I can't creat mpeg files with fluent 6.3.26
I get this error :
"mpeg_encode param1"
'mpeg_encode' is not recognized as an internal or external command,
operable program or batch file.
