March 9, 2006, 18:10 |
turbulent viscosity
if the limited turbulent viscosity ratio warning appears several times but convergence is finally reached, is the validity of the solution affected by the warning? Do you suggest to adapt the mesh of the cells which cause the problem? Thanks in advance |
March 9, 2006, 22:17 |
Re: turbulent viscosity
Just in case you didn't realise you can increase the limits of the turbulent viscosity ratio to a maximum of 1e+20. (Go to solve, controls, limits).
March 10, 2006, 07:49 |
chnaging the turbuleent specification methods in the inlet panel to intensity and hydraulic diameter wiil not give such problem
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet | Felipeb | Main CFD Forum | 1 | July 26, 2010 17:02 |
Turbulent viscosity and shear rate | shib | FLUENT | 0 | June 22, 2010 12:44 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
