Home > Forums > FLUENT
Modelling Purging of a Density Stratified Cavity
Old   March 9, 2006, 23:14
Default Modelling Purging of a Density Stratified Cavity
Natalie
Hello everybody, I am currently modelling river flows whereby the river channel has a cavity within the floor which is filled with water of a higher density (saline water). I need to be able to model the purging (or emptying) of the cavity by an overflow of fresh water, while still including the free surface effects. The water and the saline are miscible, so the volume of fluid model doesn't work for the fresh water/salt water mixing. I am using the k-epsilon turbulence model (even though I anticipate the purging rate of the saline pool will be too high with this method). I am at a loss as to which model (multiphase or species mixing) I should be using. I hope someone has had some experience modelling these kinds of flows and will really appreciate any insight anyone may have. Thank you, Natalie
Thread Tools
Trackbacks are On
Stratified flow modelling Reza_computational CFX 0 May 31, 2011 16:27
Modelling an Inverted cavity in Fluent VINEETH V K FLUENT 0 January 10, 2011 07:39
Modelling natural convection in stratified environment toyoto FLUENT 0 September 2, 2009 23:05
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
Warning 097- AB CD-adapco 6 November 15, 2004 05:41
