Home > Forums > FLUENT
NEGATIVE PRESSURE???
Old   March 11, 2006, 20:45
Default NEGATIVE PRESSURE???
REZA
HI I am modeling a cylinder inside the wind tunnel, but I am getting negative pressure up and down the cylinder and down stream of the flow? would you please help me to find the problem? thanks REZA
Old   March 11, 2006, 23:00
Default Re: NEGATIVE PRESSURE???
Ahmed
What is your operating pressure?
Old   March 11, 2006, 23:08
REZA
101375 Pa and the aditional 50 Pa is because of 10 m/s air velocity.
Old   March 11, 2006, 23:14
Ahmed
You have two options: 1- Either repeat the analysis and setting the operating pressure to Zero 2- Or add the value of the operating pressure (101325) to your results You have to understand that the pressure solved for using the Navier Stokes equations is the "Absolute Pressure" not the gauge pressure as you did.
Old   March 12, 2006, 02:24
REZA
Thanks a lot Ahmed but I tried both method, and still the problem has not been solved. air has a velocity of 10m/s. what should I exactly put for operating condition & pressure outlet? I really appreciate your help. REZA
Old   March 12, 2006, 09:15
mAx
hi, wich pressure is negative? absolute or static?
Old   March 12, 2006, 11:04
Ahmed
if you set the operating pressure to zero then you have to use absolute values when setting your boundary conditions, and do not forget the solution limits, the minimum is 1 Pa by default, it is almost impossible that you get a solution with negative values as you say, you must be doing something utterly wrong, use the Send Email button and write a detailed email with your boundary conditions or send me a case and data files
Old   March 12, 2006, 16:07
REZA
Hi mAx Both pressures are negative!!!!
Old   March 13, 2006, 02:24
mAx
local negative absolute pressure can show apparition of cavitation. But it occures only with high drop pressure
Old   March 13, 2006, 05:55
kharicha
Is your flow compressible ?
if no, then the value of the pressure is not important, only the gradient of pressure acts physically.....looks in the NS equations....the value of the pressure is nowhere. use a reference pressure equal to 0 or one. Then you get a maximum and a minimum value of pressure, and what is physically important it is the difference between them.
If yes, then the density, temperature field can change due to change of pressure. The value can be also important for example if you deal with cavitation, phase change, boiling etc...
Last thing, be carefull! your static pressure distribution (and your maximum and minimum value) depends strongly on the drag (shape and viscosity)...a good meshing is again required.
Old   March 13, 2006, 06:56
  #11
zhang
I am also have the problem too
Old   March 13, 2006, 16:17
  #12
Ahmed
mAx wrote: "negative absolute pressure" This must be a new addition to science, take your results to the Nobel committe
Old   March 14, 2006, 02:27
  #13
john
What Max said is right. He never meant that this is possible in physical world. But solver put -ve value for absolute pressure if there is cavitation. This is that way to check presence of cavitation. It is in other words 'an error'.
It is not necessary to show your such a arrogant presence, without knowing the fact.
Old   March 14, 2006, 02:57
  #14
mAx
Thanks John. Ahmed you should read between the lines. I particulary underlined the use of the term ABSOLUTE pressure, because it is naturally impossible to have negative absolute pressure. But in Fluent if you have a such domain, it can show presence of cavitation. If I don't know the solution of a posted topic, I won't post a bullshit. Please read following topic, I posted in October 2005: http://www.cfd-online.com/Forum/flue...cgi?read=32697 Over there I mentionned, that negative absolute pressure isn't physically possible. So please, read and re-read the topic before you post bullshit
Old   September 24, 2013, 05:12
Default negative pressure
  #15
PSM
pitamber.methia is on a distinguished road
Hi
I have the same problem
in pressure results it is showing the negative absolute pressure.
how it can be possible i am unable to understand. Can someone help
pitamber.methia is offline   Reply With Quote
Thread Tools
Trackbacks are On
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
seeking for help about a room with negative pressure mengyue1 FLUENT 0 November 26, 2009 07:40
High pressure in rhopSonicFoam results in negative pressure shangzung OpenFOAM 0 November 5, 2009 04:24
negative pressure in cfx flar.t CFX 1 December 19, 2006 00:20
negative pressure mAx FLUENT 0 January 25, 2006 15:31
