March 13, 2006, 12:36 |
residual oscillation
Hello, I am studying enclosed convection in small cavity and I want to evaluate the influence of gas pressure on thermal plume developped by a heated wire at the bottom of the cavity. Under 5 bar results fit well with experience, but for higher pressure, residual values of continuity start to oscillate. Perhaps somebody could help me ? Thank you. Philippe
March 13, 2006, 14:22 |
Re: residual oscillation
switch on unsteady solver
March 14, 2006, 04:04 |
Ok, but do I use small time step (and it will take a long time) or a large step ? Thank you. Philippe
March 14, 2006, 04:32 |
if you ust to large time step, it won't converge. you must compute by hand the time step you need. for instance t=(minimum cell size of your domain)/(maximum velocity you are guessing) I would use adaptive time stepping
March 14, 2006, 04:38 |
I am just trying adaptative time step, thank you very much for your answer. Philippe
March 14, 2006, 04:40 |
de rien
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 07:54 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
