Time step
Hi all how should we decide the time step in an unsteady flow?
Re: Time step
You should set a Time Step Size so that the number of iterations necessary to get convergence at each time step is 5-10. If converce at each time step requires more than 5-10 iterations then reduce the Time Step Size. If converce at each time step requires less than 5-10 iterations then you can increase the Time Step Size.
Re: Time step
You should set a Time Step Size so that the number of iterations necessary to get convergence at each time step is 5-10. If convergence at each time step requires more than 5-10 iterations then reduce the Time Step Size. If convergence at each time step requires less than 5-10 iterations then you can increase the Time Step Size.
Re: Time step
The advise above is acceptable only for small cases when time is not a critical issue.
Your timestep has to be at least 2-5 times less than a period of smallest disturbance in your flow. |
