March 15, 2006, 18:07 |
Problem with VOF
Hi all!
I am sending a question about modeling the gas injection into the liquid (focused on first stage bubble generation and flow). I used for modelling this the VOF model but unsuccesfuly. I have monitored the mass flux on the inlet and outlet. The mass indifference occoures as certain amount of the gas enters the tank. This cause divergence immediately. Is it common for the VOF? Anyway, i have very good experience with VOF for closed systems with no inlets and outlets. Is it better to use Eulerian / classic multiphase model instead of VOF for cases with inlets? If so, which 2nd phase (air or gas) particle size shall i set? |
March 17, 2006, 05:13 |
Re: Problem with VOF
I can post only the last demand: it's better to set as primary phase the lighter phase, and then patch the heavier. Don't forget the gravity on.
a problem of incompressible two phases(water and gas) with VOF Method | zhangweisnoopy | Main CFD Forum | 9 | August 12, 2011 08:25 |
Two-phase VOF problem | scott copland | FLUENT | 3 | March 15, 2007 07:25 |
Problem with VOF open channel modelling | Biswanath Mahato | FLUENT | 1 | September 14, 2006 04:20 |
A Problem with setting the time step in VOF model | Le | FLUENT | 2 | July 20, 2006 22:00 |
problem with VOF. | Marc | FLUENT | 1 | June 5, 2002 08:17 |
