axial flow around a cylinder -heat transfer model?
Old   March 21, 2006, 03:29
Default axial flow around a cylinder -heat transfer model?
Ralf Schmidt
Hi!
I am to model the axial flow around a cylinder (air, incompressible, steady, high turbulent flow). The cylinder is hot so there is a heat transfer to the fluid. Now I have some questions:
What is the best turbulence model? How to choose grid size ant type at the boundary layer? should I use a wall function???
I want to compare it to experimental values, but it is very hard to find any appropiate reference for AXIAL flow... any sugestion???
Thanks Ralf
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
question about Heat transfer between two phases with VOF model sooroo3 FLUENT 0 February 15, 2011 03:24
Distribution of surface heat transfer coefficient along the axial direcion of a tube andred FLUENT 0 November 16, 2010 21:13
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
