MRF solution data for Sliding mesh simulation
Old   March 9, 2006, 01:37
Default MRF solution data for Sliding mesh simulation
Tantular Nurtono
Dear All,
Would you like to help me. How to use MRF solution data as initial condition for sliding mesh simulation in case of 3D stirred tank simulation. Thank you.
Best reagards,
Tantular Nurtono
Old   March 10, 2006, 06:26
Default Re: MRF solution data for Sliding mesh simulation
Bunmi
Just change the boundary conditions at fluid zone to moving mesh.Also, go to the solver and change it to unsteady. then u can define yr time iteration depending on yr system
Old   March 10, 2006, 07:11
Tantular Nurtono
Thank you, I have tried according to your suggestion, however, there are two message: 1. error: divergence detected in AMG solver : pressure correction 2. error object: ()
I am worry about the boundary condition between moving and stationary zone, still use the interior or change to interface?
Thank you.
Regards,
Tantular Nurtono
Old   March 10, 2006, 08:17
Bunmi
For moving mesh, u make use of interface between the stationary and moving frame. U can either use interior or interface for MFR but for Sliding mesh/grid, interface is only applicable
Old   March 20, 2006, 21:18
Tantular Nurtono
Many thanks Bunni, I am success to do it. Best Regards.
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Export simulation data to 3d mesh dlugi OpenFOAM 0 May 19, 2011 04:47
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
