k-epsilon model/turbulent intensity
Old   March 13, 2006, 11:22
Default k-epsilon model/turbulent intensity
Erika Johnson
Has anyone had any success with the k-epsilon model working for small values of turbulence intensity 5% and a turbulent ratio of 10 at the inlet??? It is my understanding that it is general practice to use these values.
I want to know because I'm simulating a wind tunnel experiment where the inlet turbulent intensity is about 0.5% - 1%.
Thanks so much, Erika
Old   March 14, 2006, 00:26
Default Re: k-epsilon model/turbulent intensity
sam
i have used that it works well using k-epsilon with RNG & Reliazable k-epsilon
Old   March 21, 2006, 09:54
Erika
So would you not recommend using the standard k-epsilon model if your freestream turbulence is very small??? Does it not work well in those situations???
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
calculate k and epsilon from turbulent intensity Ralf Schmidt Main CFD Forum 6 March 24, 2006 05:50
How CFX calculate TKE and Epsilon from intensity? David CFX 0 November 24, 2005 04:53
